1 - 20 of 29 Posts
Hello all. I was looking at a parts car near by today and I notice 2 vin plates on the radiator mount. There was the vin that has been stamped along with 2 plates. 1 plate had the mercedes name and looked very original. The other looked like a plain piece of metal with a vin along with some other numbers stamped on it. Is this normal? Are the 2 numbers supposed to match? These two vin numbers were not the same. I would love to check my car out but its put away and I wont be at my warehouse for a few weeks. Any info would be appreciated because my curiosity is at it highest peak right now
1967 250 SL, 1965 300SE lang
The one starting with 114 023 is the VIN for a 250C. The other might be the chassis number or something else, not 100% sure. Go with the one that starts with 114 023.
Thank you for your answers. I have read online that a 114 023 is a 250c from 69 to 73 and that a 114 623 is 73 to 76. Am I missing something? MikeD you link to peachparts has both numbers as 114 023. I am just curious because I want to be sure parts fit, also I can pick up whole car for 400$ and want to be sure this car is legit. Thank you.
Formerly madmanmerc
'72 250C, '74 280C, '85 500SEL, '81 300CD.
Starting with the 1973 model year, 280's were powered by the M110 engine. This necessitated a change in the engine compartment to facilitate the DOHC in-line six cylinder. The cross support braces were eliminated on the W114's but retained on the W115's. There were a few other cosmetic changes, different grill, hood, exhaust, etc. but nothing of any major consequence.
Scoot it's a 114 623. Could these be 2 different bins. I read on wiki that 114 023 is 250c 114 623 is 280c. Is this possible?
To the best of my knowledge, no. I think a 280C is 114.073.
Discussion Starter #11
You are right Scoot. As per wiki 114 073 is 280c. 114 023 is 250c from 69 to 73 and 114 623 is 250c from 73 to 76. Now I am just unsure as to why these to plate would have different numbers. Thank you for your patience with me
The problem I have with it is I don't think a 250C existed in production from 73 to 76.
It appears the "623"'s were a very limited production. Only 1100 or so were made. I imagine the low numbers produced were the result of Ma Benz using up the existing supply of M130 engines already on the shelf. I've never seen a '73 or later model using the M130 but then again, I've never seen a Narwhal and I know those exist.
The answer to this, and other mysteries, can only be found in the minds of the engineers. Try contacting Daimler-Benz for the resolution of this puzzle.
68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Post pictures of the plates. on some models the plate shows the body/chassis number which is different than the vin.
Discussion Starter #19
As you can see the vin engraved and the one on the mercedes plate is 114 023 and the one on the generic metal plate is 114 623
I think the 623 on the plate is chassis number not vin.
1 - 20 of 29 Posts
