I'm thinking of buying the used 2006 C280 with 77,000 miles. I'd like to know if the engine is one of the problem childs. Thanks for any help!
Discussion Starter #2
Sorry to bump this, but I'm going to look at this car again tomorrow. Could someone with access check out that vin# for me? Thanks!
WDBRF92HX6F783720 has M272 engine #266780 which is within the affected range for a defective balance shaft.
Thanks for checking. Do you think it's worth buying if I can pick it up for wholesale price? I know the history of the car & it has been maintained correctly. I do have an set up at my local Mercedes dealer where I get a break on parts & labor. Or should I stay clear?
Personally, I'd stay clear. Even the best maintenance can't prevent the problem. It's going to fail early, just how early is unknown. When it does fail, it's a $4K+ job that requires pulling the engine. The parts are not too bad, I think around $400. It's the labor that's the killer.
Check the other thread where you asked the same question...
