1 - 11 of 11 Posts
2001 SL500
All the posts on this topic are poorly written and there's conflicting info. I've never seen a video of this done, and I think a video fully showing us what to do would be very beneficial for this sub-forum's DIYers, and could make a very useful resource under the "Helpful Links" sticky.
Could someone kindly post said video?
Thanks in advance
Thanks in advance
Great Idea...Thanx
94 SL320 98 SL500 99 SL600
Thanks in advance
There are 4 jack pads under the car. Just use the jack in your trunk and place a jack stand under each pad.
97 SL600 Pano, ex: 96 (late 95) SL320
PelicanParts has an article with good photos on the topic. No video but good info.
I wouldn't use the car's own jack unless in an emergency. It's a pretty shabby and unstable thing compared to a proper floor jack and not really meant for frequent use.
M113 SL500
I bought a set of these with appropriate Mercedes stand adapters. Works really well. Don't need to buy a long reach floor jack to try to jack the car from central jacking points.
2000 SL500, 2001 S600, 2004 E320
Thanks for the link, this is perfect solution for my needs… I hope it works as well as it looks.
Question about Mercedes adapters: did you get both (18M-P10 and 18M-P20)… do they both perfectly fit respective applications?
M113 SL500
I got the one for round jackpads we have in our R129's. Upon removal, the adapter cup gets a little stuck on the angle of the jackpad because the cup is a smaller diameter than the widest diameter of the jackpad. I kinda see it as a plus, as I think any radial play between the cup and jackpad probably doesn't help safety wise. Not a big deal. The adapter just stays stuck to the car when the rest of the rennstand is removed and requires a little pull to remove.
Thank you, that's good to know. I thought it would be tight when I checked dimensions posted on their website. I'll need the other one too, for the slotted jack pads on W211, but these should fit with millimeter or two to spare.
1 - 11 of 11 Posts
