1 - 20 of 71 Posts
Hmmmm...I'm nervous about the neighborhood it was done in, and why so much moving of the steering wheel.......curvy residential streets? Scary!
But that's just the adult in me talking. The rest of me says........
...........AWESOME!
Sounded great too. What was the actual 0-60 time? Did you clock it? Your car hauls ass.
I did the same thing in my 560SEL Euro the other day.....manually shifted to "B" and then back to "D", floored it, and left 25-30 feet of black on the concrete on-ramp with no axle tramp...a perfect smooth burnout start with no left foot braking!
And that was with 3-piece wheels, 10" wide in back with 265/40/17 Dunlop Sport 8000's. Man I'm gonna miss that car.
Jonathan, where's your video so we can hear 370HP laying rubber?
E320
well technically it's considered residential. but all the housing is blocked off to the right side so i deemed it safe. otherwise i'd never go more than 5mph over in residential! the road curved a little so i did have to turn the steering wheel, but my alignment is perfect now that i took care of those bent tie rods. i didn't clock it, but if i had a stopwatch i could figure it out from the video. it's obviously not gonna shoot away as quick as your euro 560! haha.. i can't imagine. especially if your lighting up 265s. i bet even feathering the throttle does nothing to control the wheelspin. it'd be awesome to see a video of your 560, though. ECE i assume? isn't that the white one?
No, the blue one. The white one is nice and fast, dropped it off for Dr. buying it that lives in Indiana.....customer of Jonathan's. It's a great car, he bought my chrome AMG 3-piece wheels with new tires. Looked wicked that way.
But the blue one, I think, is even more powerful. Longer throttle, you really have to bury it to get the power (probably stretched linkage). But man, when you do, it flies.
E320
which one did you just sell? didn't a guy come out, drive it, and cut you a check? was that the identical SEC? how much did you sell it for? $2500 on ebay is rediculous, probably not half the reserve, was it..
The white Euro SEL sold a long time ago, but it took me a while to get the title, so I just dropped it off.
The Blue Euro SEL, almost identical but with more miles, just sold when the guy came out to look/drive earlier this week.
1982 380SE AMG euro(parted out),1983 300SD "Good Girl", 1984 500SEL AMG euro "Bad Girl"
NüR-SPEC said:
i didn't use the brake to raise the rpm because i'll just get more wheelspin anyway, but still.. not bad. what do you guys think?
YouTube - W126 euro 500SEL 0-60 time
Nice! I'm getting bad thoughts though. Might just charge the camcorder battery for a triple digit run :)
E320
doooo it!!! haha..
i'm considering a high speed run. i'd just feel much safer if i had somewhere to mount the camera with a front view aswell as a good view of the guages. i'll probably do it after i sort out my suspension.
2005 W220 S500 4Matic / 2008 W211 E350 4Matic
You should definitely clock it - YouTube shows a little over 8 seconds from launch to the end of the video - I can't read the gauge, so no way to tell for sure. That sounds awfully slow for your car... I'm guessing you are running well under that figure.
E320
Discussion Starter #11
really? i clocked it at 6.8 seconds before.. maybe i'm just losing power due to higher ambient temperatures cause last time i tested was at night a month ago. anybody know the factory tested 0-60 for a euro 500 SEL?
Maybe the timing of the YouTube video is off due to lag time in turning off the camera? The acceleration starts at the two second mark, and the video is 11 seconds long in total.
E320
Discussion Starter #14
well, it is an SEL.. and it's not a 560. is my car lacking? didn't seem like 10 seconds to me.
1983 Euro 500SEC AMG, 83 SEC custom convertible, 2x 84 500SEC, 02 w203coupe, euro 1985 300d
DISCLAIMER DISCLAIMER DISCLAIMER CHILL CHILL CHILL---ok you can read this now
had to do that----not getting in a pissing contest at all but tad over 6sec is not really obtainable with a US engine even with exhaust work done--7-8 maybe but the track times will prove it better--- When i took my US 500sec with headers, k&n air filter 9in rear tires and dual exhaust, with new timing chain, valve seals and rebuilt transmission. I was only able to get 7.65 and that was best of 3 runs @ 60 degrees at a level track
bone stock average when US engine was new
1984 Mercedes-Benz 500SEC 0-60 = 9.0 1/4 mile =17.0
1985 Mercedes-Benz 500SEL 8.9 17.0
Eurotuned Automotive Performance - Acceleration Times
0-60 and 1/4 mile times for Factory Stock Vehicles
0-60 mph and 1/4 mile times for Factory Stock Vehicles - Street Racing Videos - Drag Racing & Drifting
now if i was only able to get those slips to prove it---before there is any retaliatory action--- I don't even worry about the 0-60 times when the 75-135 times are so much better!
E320
Discussion Starter #17
also note my odd issue where i can't get to redline in 1st gear. i did pretty good on this run, but usually if i get a good hook up it shifts at 3500rpm.. still scratching my head on that one.
have you tried adjusting the tranny??? i found that turning the T key counter clockwise helps a little--i know it is more for tigtening the shifting between gears but it might work for you to play around with the shift points--could be why it is shifting too soon
also I had a euro 500sel for the longest time and lived in it--the o-60 times were closer to 7 than 9 with the barrel headers and full AMG/sebring exhaust
it is too bad they won't let me take my convertible to the track without a rollbar and top up-- or I could find out what a euro 500 motor with free flowing brabus exhaust and lower gear ratio would be able to obtain!
for an older transmission , i used to flush them with a unit called T-Tech which purged the old stuff out while the car was running through the lines too and from the radiator, while it pushed new stuff in. It collected it in a clear cylindrical lighted tube so you could see all the crap coming out of the return line and floading around thick and burnt.....it worked well on most of the imports, however I found after doing this on the US cars they were sloppy as hell!
1 - 20 of 71 Posts
