1 - 8 of 8 Posts
1999 Mercedes-Benz E-Class Estate 2.7CDi 125kW
Hello!
So there is an annoying vibration, coming from underneath the seats/rear end when driving along. It occurs when u hit the gas and even at cruising speed. From 65 km/h to about 90km/h. After that it clears up and there are no vibrations.
I have read that w210's are notorious for vibrating, but i just cant stand it.
I have changed flex discs, today replaced diff bushings. The subframe bushes are new.
Have to mention, that car rear end "moves" when engaging from N to D or R. Even with all the new bushings.
What to look next? Maybe the gearbox itself is worn of diff is worn (when it was off, there was very little play between the both sides)?
Transmission mount bolts?
Center bearing?
If you replaced diff bushings and still have movement, I'd look at your LCA bushings on both side at rear. Common issue.
MY05 CLK55 AMG ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Check the Driveshaft and the centre support bearing..
1 - 8 of 8 Posts
