2002 ML 500 Sport
Having vibration problem while driving but not constant it drives nice for few days than some days vibrates not sure what it is.Changed 2 sets of tires and wheels still same inspected wheels for play and tie rods only visible thing that is slightly worn is sway bar bushings at front just have bad feeling for bad bearings or drive shaft problems? Any help :confused:
Super Moderator
Drive shaft center support bearing or a really very bad wheel bearing, but the wheel
bearing should be making a heck of a lot of noise.
ML 270CDI 2002, BMW K1300S, VW POLO 1.9TDI
I had a similar problem, it turned out to be excess play on the large UJ coupling on the front propeller shaft. Had to replace the complete shaft as no repair is available for that particular joint. (got a used one for £50)
