2000 S500 Kleemann, 2007 S550
Would 1 loose bolt on each of the rear wheels cause the car to vibrate at highway speeds?
08 ml320 cdi,slk 230,01 boxster S,04carrera911, 99 S320,67 GT350mustang,02G500L,96 s600 w140, e55 2k
hmmm nope i dont think so
2000 CLK 430 Cabriolet 2003 S500 4Matic 2004 S55 2005 CLK 500 Cabriolet 2008 S 450
IMO provided the other 4 bolts were properly seated and tight it is very doubtful it would cause a vibration
Current 2017 GLE350, 2007 S550, 2002 S430, 1998 ML320 Deceased 74 240D, 92 400E, 97 E420, 13 GLK350
After checking wheel lugs
Try checking the flex discs on the propeller shaft. (Substituted for U-Joints on a drive shaft) After 100,000 miles, the rubber has a tendency to start to come apart. Posts show catastrophic damage if left unattended. A common sign of problems is vibration at highway speeds.
One other thought - if you have recently lost balance on a wheel from hitting a curb, or tires are worn down, these could cause symptoms.
Good Luck
2002 s500, 2004 S500 fourmatic
What kind of vibration?
A mechanic friend of past once told me that tire vibration makes the steering wheel vibrate, but if you feel the vibration in the seat (or in your crotch), its probably the drive train.
At 60mph, the tires are putting 10 to 15 hertz (HZ) of vibration. That's reasonably fast, but (and I don't know what your differential ratio is) referencing the Rolling Stones and their 409....the drive shaft turnes 4.09 times for every turn of the drive axle. I'm guessing MB's use somewhere around a 3:1 or 3.5:1 ratio which at 60mph would have the vibrations anywhere from 45Hz to 60Hz. Although it may be temping now, it matches the frequency of your home power. So my question is what kind of vibration frequency are you exhibiting?
