1 - 17 of 17 Posts
2014 C350 coupe (RWD), miles: 1k & 2014 Infiniti Q50 AWD, (lease), miles: 10k & 2000 Ford Crown Vic
This is an incredible general question so I apology in advance.
Why am I getting vibration in my steering wheel?
I noticed it a little right when I got this car but because the last driver was my father and I got a good family discount I didn’t think twice about it, after I drove my work car a 2000 Crown Vic with over 105k with no vibration in the steering I started to worry.
I am thinking this might be the tires, they are not worn out and still have ok tread but they are old, 3 years in South FL weather. the tires seem “dry” if that makes sense.
Also, there are no issues with the air suspension but I have never owed a car with air suspension so the vibration might be because of this. The alignment on the car is fine/perfect and the car only has about 38k (miles).
Any info would be helpful and thanks in advance.
06 E350 4Matic
Kirill -- this may not be your issue, but we are in the same general area, so thought I would post.
The tires on the car when we purchased (used) were ContiSports. They also had good tread, but over time the road noise and vibration increased. Balancing helped, but it did not resolve the issue to my satisfaction. One day, the left rear tire just went flat from a split in the sidewall. Luckily, the car was parked in the garage at the time. When talking with TireRack.com, the rep said that the mounted Contis were Summer tires and simply dried out from year round use in this area. I switched to all season Michelins.
Yea, I think I will buy these tires, anyone doesn’t agree?
Michelin Pilot Sport A/S Plus
Thanks.
E350 4M 06
Can't go wrong with the Michelins, I'm using Conti DWS and they're very good, I have about 45K on them and they can handle 10 more, still quiet and much cheaper than the Michelins.
I had good experiences with Michelins plus tires are the first safety feature in any car, sometimes people forget that good tires are sometimes better then 20+ airbags.
I did say sometimes… :).
Btw, I am a (kind of) new member her. Thanks to all for the advice and explanations!!!
They are always appreciated!!!
Back to your original post, did you have the tires balanced lately?
No, have not. Isn’t balancing a time thing (unless accident or you crab your rim hard)?
'05 E320 CDI Black/Black
Rotation - Yes...... more of a mileage thing then Time, but balancing never hurts as per "feel"/hence meaning of your topic/.
Actually , I have somewhat similar "feel at the wheel" and I'm running Michelin's Pilot Exalto A/S 80% tread remaining, and I did appropriate time/mileage rotation and balancing at MB dealer , that tiniest vibration still come & go time to time..So kind of curious myself what can cause it.
E350 4M 06
I suggest that you do so, I have seen steering wheel vibrations creep up after a wheel weight falls off, uneven tire wear, even tire wear and long miles, etc... Also if the wheel and tire are not matched for balance and you end up with 2 or 3 ounzes of weight in the same spot then the slightest aberation in the setup will cause vibration, in that case, the tire shop should move the tire wrt the wheel, usually 180 degrees.
Unless you have belt separation, dry tires do not vibrate if balanced, the way to test separation is to drive on a smooth road at 30 mph and let go of the steering wheel, if it wiggles, then chances are your belts have lost adhesion and its time to change tires.
Purple Moderator
If the tires are getting worn out then they can start vibrating. If you are getting new tires
in the next couple of weeks just wait till then.
98 E-320, 2003 E-500
Could be the engine mounts deteriorating. On my W210, I felt a growing (little) vibration as the car aged (6 year +). It continued to get worse until becoming too noticeable.
Soon as I replaced the mounts (and the tranny mount) the vibration went away totally.
Discussion Starter #15
That is the plan!
Thanks.
If tires look fine and vibration is not isolated to braking, I would suggest having all four “road force” balanced utilizing Hunter GSP9700 Wheel vibration Control System solves wheel vibration and tire pull problems that balancers and aligners can't fix
Thanks for the tip Konigs.
Went today to place with this miracle machine you suggested & they balanced all 4 tires with ROAD FORCE......... that tiny vibration I felt time to time is GONE.
Turned out to be inside one of the tires was trapped smallest amount of water ( maybe 3-4 table spoons ) saw it with my own eyes when they took tire off after machine was keep getting different readings. What a fine precise calibration this equipment has - VERY Impressive.
Cost of ROAD FORCE balancing was $15 per tire.... but these guys just did it for FREE and even replaced air with Nitrogen.... def.earned my business with such customer service.
2005 E500S4
I would recommend an alignment as well. Just because it is steering straight does not mean the Toe in rear, or even front is not off. Also with crown in the road sometimes it is difficult to tell if alignment is off. I had an alignment problem on my "05" E500 wagon that would cause the car to chew up the rears till they started to make a lot of noise but never out of balance or causing the car to pull to one side or the other.
With an alignment and new set of tires the car should feel like new.
Jeff.
1 - 17 of 17 Posts
