1 - 1 of 1 Posts
1996 S320
AssMan this is for you.
I solved my vibration. I changed out the tie rods and upper control arms. But I will tell you this. When I did it I still had vibration but my ldriver side wheel had play when you lift the car up. I had play from left to right and I found out the driver side tie rod was not tight enough. that was were my play was. the mechanic tightned it up with a air wrench and I drove it down the road and WOW!!!!!!!!!!!!!!!!!!!!!!! Smooth. No vibration I have Michelin Primacy MXV4 235/60/16" and I'm running 28psi fronts and 30psi in the rears.
1 - 1 of 1 Posts
