Hello all, back again with a new issue. Just recently, I got into my car and fired it up. It vibrated noticeabally for a minute or so while in "park". It finally settled down a bit, but was not as smooth as I am used too. When I put it in reverse, it intensified a little more. Then I put in in "drive", and it did it for a sec, then settled down. I feel the vibrations more at RPM changes (stop and go). My first guess was motor mounts. I have read that that is a common problem on these cars (2001 E55).I have never had a problem with them in the past, so I figured it's probabally time. I just hit 91K on the Benz. I drove with my hand on the shift lever to see if i could feel any movement. I definately felt the shift lever moving under acceleration. (it moved forward?)It also moved from side-to-side under hard cornering. If it were a dampner or balancer, this wouldn't happen right? It's not throwing any codes or anything and the car runs and starts fine. I just replaced the alternator recently, so I've been enjoying my car alot lately if you know what I mean? It's been running fanatstically. Also, I've started driving it with the traction control turned "off" because it just seems quicker. Does the tracton control allow the car to be "torquier?" It seems logical that the motor mounts or tranny mounts could break as the car feels alot more "brutal" with the traction control off? Any feedback or advice would be appreciated. It's not really a horrible vibration that renders the car "undriveable". It's just obvious and it's got me concerned. I can feel it in the footwell. Kind of like if you were leaning on a large industrial transformer. It's got almost an "electrical" kind of "hum" at times? Thanks
