SLK 350 (2006)
Okay, I have been monitoring the progress of the MB bluetooth cradle and was pleased to see people successfully use their Verizon Razr with no apparent problems. So I tried to order one from AWS and they said "It isn't on MB's approved list and you have to sign a waiver that you know it isn't approved and if you have any trouble, you can't return it. And it could cause your Comand to hang up!"
I would have thought by now with a popular phone and a popular supplier MB would have tested it and either said it was a go or not.
So I have seen several people saying it was working without problem and I believe they had the version of software I have which is GATW-01.0F.03.
And I know some people have been reporting odd Comand hangs. So does anyone think the problem is related to a Verizon Razr with the BlueTooth cradle, or should I just sign the release and order the cradle?
SLK 350 (2006)
Discussion Starter · #2 ·
Ooh. and my Razr is a V3c in case that makes a difference.
Oops. Forgot that it is a V3c. I knew I would forget something :)
