1 - 9 of 9 Posts
Can someone post a schematic of the vent window latch assembly for a 406?
I got the repair kit and some new glass for my vent windows. The top pin was broken on one so I was able to silver braze it back - here’s a picture. Over the course of a few weeks of interruptions and repairing and painting the frames, I can’t remember which side the little gasket goes on.
Also, any tips on what kind of adhesive to use to fasten the glass to the frame? I found this stuff called “strip caulk.” It’s gummy adhesive for automotive repair.
As far as what goop to use to seal the glass into the frame and/or gasket, I'd go to the best rated glass shop with the pieces in hand and ask the question.
Over time, new products have been developed, and some vehicles use a 'Dry Mount', where it is just a pressure fit between the glass, the gasket and the frame, and some use a 'Wet Mount', where a bead of goop is put into the channel of the frame or the gasket before assembly.
Since your UNIMOG used a Wet Mount, I'd check with a pro to see what the latest and greatest stuff is. I'd bet there is new stuff that is superior to whatever was used originally.
Not sure if this is any help?
Thanks. The schematic shows a wrench near item 58 (window latch). I'm just guessing that is the repair kit, of which I bought two (one each for right and left sides). Is there any assembly info for the kit?
For reference, one of the kits is A 347 586 00 67 (not sure if that's left or right)
What I’m trying to ascertain is which side of the glass does the flat “D” shaped rubber gasket go? Only one is included in the kit.
EDIT - looks like it goes on the inside.
Thanks for the advice on adhesive. I assembled one with the 3m “strip caulk” because I had it and it looked promising. I don’t know of any auto glass experts here, so tracking one down may take some effort but would be the next option.
The Strip Caulk might work out fine, but it is made and marketed for non-glass seam sealing in automotive applications.
Basically, it is a solt Butyl rubber that adheres to most any clean surface, and it made to fill
"seams, joints, and gaps". Another sentence specifies that it is " for filling non-visible automotive joints, seams, voids and gaps.This thumb-grade seam sealer arrives ready to install without mixing, spraying or tools. It thumbs in quickly and smooths with a fingertip. .....Etc."
It is the modern version of what they used to call Dum-Dum, which did the same thing : Seal up edges and gaps where two sheetmetal panels butted up or overlapped, before or after painting.
For glass installation 3M has a few products but for side glass, they indicate that "3M 08609 Windo-Weld Super fast Urethane" is the stuff. It comes in a caulk tube for $23 via Amazon.
If the strip caulk works out, then great.
I'm just adding the 3M glass Urethane in case you need to go to that.
Looks like I was too hasty to get this reassembled. I’ll look into the alternate material - thanks for your insight.
1 - 9 of 9 Posts
