1 - 14 of 14 Posts
1991 420 SEL
On the other car make forums I've belonged to over the years, there was often a thread to post parts sales etc, not by the poster but just things they've come across.
No affiliation etc, no guarantees, if you see something someone might be interested in post it.
If there's any forum rule issues with this please delete it.
This is why I brought this up, I came across this:
Mercedes Benz W126 4G-Tronic Automatic Transmission $175 in Ohio
And a seller on Amazon still shows 4 ea of the Swag camshaft sprocket gears that are apparently no longer made, 1160520601
Anything else interesting out there?
Pete
1991 420 SEL
The correct EHA orings for my 19 420sel are less than $4 inc shipping for 10 ea on Amazon,
uxcell Fluorine Rubber O Rings, 10mm OD, 6.2mm Inner Diameter, 1.9mm Width, Seal Gasket Green
The 'felpro' valve cover gaskets I bought on closeout ($11 plus frt) from Rock Auto have 'elring' stamped on them. FEL-PRO VS50404R
Pete
1991 420 SEL
A couple Rock Auto closeouts, these come up for my 420SEL, check fitment on yours:
RAYBESTOS 96224 front rotors $23 plus frt, they are coated 'street performance' - I use them - good deal!
WAGNER ZD31 QuickStop; Ceramic rear pads $6.00 plus frt
Moderator
1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Pete
Might we include the URLs for these items please? Or have I been mistaken?
MBL
1991 420 SEL
I can, I prefer the entire description and / or part number in case the URL changes, but will add them from here out.
EHA orings: uxcell Fluorine Rubber O Rings, 10mm OD, 6.2mm Inner Diameter, 1.9mm Width, Seal Gasket Green 10Pcs: Amazon.com: Industrial & Scientific
Did I mention, those front rotors on Rock are a very good deal? But Rock is messed up. In order to get the closeout price you have to go through the 'rss' feed if you know what I mean? The little orange button next to where it says the engine size, click that, then click it again next to 'love a bargain?' - if it doesn't work once, try it again later, maybe it'll work? Weird.
Pete
1991 420 SEL
Looking for a new gas cap gasket I found these new complete gas caps for not much more - I offered $10 and accepted the sellers counter of 12.50
And a note - the gas tank strainer for my 420sel is discontinued. Better get one while the gettin's good!
Pete
'87 560 SEC, Pearl Grey/blue; 300,000+ mi; '07 CLS 550, Barolo/stone; 90,000+ mi
For years I've had what looks like black mold growing out of the fuel flap area. Is this from ethanol fumes getting past the cap gasket?
1991 420 SEL
Gosh I'm sorry Drew I have no idea. I'd start a thread on it.
The gas cap I mentioned above came in, the finish is rough and flat (not shiny) - any idea if this is correct? My old cap is both smooth and shiny.
Pete
Moderator
Hey Pete,
Both my Gen2 SECs have a different shaped cap than the one pictured in the Ebay ad.
They appear like this one in the pic and the finish is identical.
MBL
1 - 14 of 14 Posts
