I just had both Vario Roof Drive Flap Gear Housing replaced on my 05 SL under warranty. There is a DTB (Daimler Technical Bulletin) for the original housing. They flex and cause the flap to sag and as seen in the attached photos will eventually cause the flap to drop and the roof will not open or close correctly. The DTB number is seen on attached photos. Part number is 230-750-01-11. Mine was rattling when driving on a rough road. I'd recommend having them changed if you see any indication of sagging as seen in the first photo. Be safe...
