B1271-vario roof "open/lowered" limit switch (S69/11) & vario roof " closed" limit switch (S69/1) actuated simultaneously.
Fix? Maybe unhook battery to remove error message/computer confusion? Could it be that simple or does anyone else have any ideas?
Golf R32 / Prev R170 SLK
Well it wont hurt to try.
Sounds like a stuck sw even if its fixed itself. As I have posted many times there is an MB bulletin to remove clear bellows of sw as they make them stick or stop them working properly.
Later fix was/is to replace switches completely.
Bazzle
1999 SLK 230K
I just bit the bullet and replaced 4 switches at $20/each. Actually have one more to go in but the problem was so intermittent that I decided to just swap the four instead of try and troubleshoot it. For $80 total I figured it was worth it.
Avery
01 SLK 320 MT6
How did you pull these codes ? Dealer ?
