1992 300SL
I posted this a couple of days ago but it did not make it to the site so I will try again. I need to figure out who the disconnect the vacuum lines that control the hvac flaps. so I can remove them.
Motor vehicle Automotive tire Vehicle Automotive design Automotive fuel system
1992 300SL
Easy,
Use a 7mm open wrench, on the white part, push down,against the black.
Regards,
aam.
The 7mm wrench worked great. Now when my second speed controller/resistor gets here tomorrow I will find out how easy the vacuum tube connectors go back together. If anyone out there needs to buy a speed controller from Rock Auto do not look up the parts using their parts finder because it is wrong! Look up the part using the MB part number, at least I hope they send the correct one this time.
