Hey mates...hopefully you can help me diagnose this problem. I have reviewed the Brake booster tips etc prior to posting this. Here goes... just had my mechanic change the rotors/pads/master cylinder and reservoir on my 1980 300 SD. Now never had a problem prior to this with vacuum or brake booster..the engine will not shut off now on its own...the pump is sending necessary pressure to the brake booster...HOWEVER...very little pressure is leaving the brake booster..hence brakes are hard and the engine stays running..could there be something my mechanic had done incorrectly when he installed the master cylinder? improper seal perhaps?? Any suggestions...NEVER had any of these problems prior to him changing the master cylinder out. Most greatful for any and ALL suggestions. Thanks mates! CHEERS!
