[?]I need to change the vacuum shut off valve that is mounted on back of injection pump between pump & oil filter housing. All Data shows to just remove the 4 retaining bolts & remove valve. it looks a little more involved than that. do I need to remove oil filter housing& how do you unhook the old valve & re-hook the new one? I would think that if you don't hook it up right the engine might race when I start it up.[xx(][xx(]NOT GOOD!
THANKS FOR ALL THE HELP
