1 - 12 of 12 Posts
1999 S420
I tried looking in the forum buyt I did not see anything related.
On a 1999 S420, per theb vehicle emission control diagram, the lines color coded TR, TR/BL/ & TR/BL are all cracked . The 2 lines go from the switching air valve & map sensor to the back of the engine (via under the the manifold) need to be replaced.
Do I get these lines form the dealer only. Are they replaced by the rubber vacuum lines? the original ones feel like plastic.
1994 S600 Coupe, 1995 S600 Coupe
You can replace them with generic plastic line available at auto parts stores.
Mercedes sells the line in bulk form, but the last time I tried to buy some, different colors weren't available, just generic translucent white. They do sell the molded rubber end fittings, sometimes with needed acute or right angles, depending on the application.
Jon
1999 S420
Thanks. I will have to get new molded rubber end fittings too. But I was also wondering if the plastic lines hold up better than the rubber lines? I saw the plastic lines under #0001589135 in autohausAZ
1984D Turbodiesel, 1999 S420, 1997 S320, 2016 E350
HELP......Hope I am not hijacking this thread but Mava is busy with school he fixed my pse pump last year. I have a leak from what I have read in this forum it is advisable to cap the the bladders so I looked under both front seats and they are two lines under each seat what to do cap both lines under each seat and what to do at pse pump
Cap it either at the pump, OR the front of the seat. There should only be one line at the front of each seat for the bladders.
Jon
Thanks John but on my car 1999 S420 there are two lines under each seat
At the connector for the line coming from the floor to the seat?
A picture would help.
Jon
You can replace them with vacuum hose
1989 W124 260E
These pipes are easy to find,, but do check to see if they are fuel prone i know they dont take fuel through them but they do come in to contact with fuel and oil when used on or around the engine .
1 - 12 of 12 Posts
