W-1-2-3 Go!
Hi,
There are an abundance of three-way and four-way fittings in and around the W123 body, engine and interior. Aside from that, there are plastic color-coded lines that run throughout the car. The plastic lines are the main paths of vacuum while the 3 and 4 way fittings are the "joints".
www.germanstar.net
www.performanceproducts.com
www.autohausaz.com
These sites should have them. The local dealer might be of help too, but my experience goes to $how that your wallet will $urely be empty. You could try your luck.
Vacuum connectors & hoses (2 way):
http://autohausaz.com/catalog/lookup_parts.cfm?SubcategoryID=5024&VehicleID=1193778&CFID=507846&CFToken=40096281
Vacuum connectors (3 & 4 way):
http://autohausaz.com/catalog/lookup_parts.cfm?SubcategoryID=7032&VehicleID=1193778&CFID=507846&CFToken=40096281
Vacuum elements (actuators, locks, etc):
http://autohausaz.com/catalog/lookup_parts.cfm?SubcategoryID=4881&VehicleID=1193778&CFID=507846&CFToken=40096281
1980 300D
sorry for the late thank you.
good info!!!
me thinks this is where my restoration should begin, or at least shortly follow a couple other neccessities.
It's real hard to make a diagnosis of problems since everything in or on the car seems to stem from the vaccum system.
thanks again
