Hi RES, you sent me a private message yesterday and below the line was my response.
The VACUUM RESERVOIR is located inside the driver side wing/fender, see image here…
98 MERCEDES BENZ C230 W202 VACUUM RESERVOIR 2108050119 OEM | eBay ... follow the green vacuum tube from the manifold block ( Or Pneumatic distributor connector), picture below.
The link I gave you in my last poste details the where each vacuum line goes to.
Quote “Customer :
hook up is as follows..
Port 1 - Unused
Port 2 - White from Vac pump in trunk
Port 3 - Unused
Port 4 - Black / White to bottom of Vac Res in pass fender
Port 5 - Black / White to Kick Down Relay near OVP relay
Port 6 - Red / Black to top of Vac Res in Passenger fender
Port 7 - Green to HVAC Valve block in passenger dash
Port P - White from intake manifold”
From the vacuum pump, all the Yellow lines go to doors, fuel flap and trunk lock. The Grey Or White line goes to the engine bay.
If there is a leak in the manifold block (crack at the metal ball) then you must fix or replace that first otherwise you are wasting your time checking other stuff.
Dec
