1 - 9 of 9 Posts
1990 Mercedes 300se first car!
The car will not accelerate normally under 35mph (it's worse than grandma driving), and the transmission shifts really hard. It gets a little better when the car is warmed up but not much.
1986 420SEL/1995 E300D/4 BMW’s/2 Vanagon’s
First step is to get yourself a mityvac.
Vac problem
That narrows down the vacuum issue. Do you have a manual?.There are vac diagrams in it. If you don't have one I think you can download a freebie. I believe Mclare (spelling?)is the "manual guru".
MityVac mentioned above allows you to test each line to confirm it's holding/can hold vacuum.
· CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
The 'new members please read, welcome....' announcement on top has the W126 service manual which includes the M103 engine. The vac diagram should be in there.
Otherwise, The W201 forum FAQ sticky has a manual with the M103 2.6 L which should be similar.
The announcement will also show how to search the forum with 'vacuum leak' etc on how to pin point vac leaks.
The diagram should be in section 14-050.That seems to be the common section in the manuals. Some manuals don't show the colors in English eg black may be Swartz, red Rot etc. The US one s/be English though.I've experienced difficulty because my RHD 107 has some colors different to US manual diagrams because of the difference in emission control. I have not closely inspected my V126 yet, but it's a 420.
Also, be aware that there maybe differences between year models (there are for 107's)
Good luck
· Outstanding Contributor
1989 560SEC, 1989 560SEL, 1995 E420
I've experienced the hard shifting. A vacuum line at the back of the engine had fallen off. I would check very carefully all around the engine to see if that has happened on your car.
1 - 9 of 9 Posts
