1983 280S euro, 2004 C180 Komp
Hi i have a 1983 280s and now i am having problems with the locks, when i unlock the car from driver side nothing happens ( none of locks go up or down ) but when i open all the doors manually and then lock the doors from the driver side ( all doors including doors gas and trunk ) will lock however the pump will still continue to run for about 1 min.
· Super Moderator
1986/1990 W126
Its very common, loads of threads for you to look through to find your particular issue.
You likely have a leak (The pump runs until it shits itself off automatically, they do this after about a minute if no signal is received.) as well as perhaps a faulty microswitch. (The thing that sends a signal.)
Hi, where is the microswitch located?
· Super Moderator
1986/1990 W126
At the doors. But to get a better understanding, have a looky through the search archives, theres loads in there and it saves repeating the same old thing.
You might check your fuel filler locking element for leaks, hissing etc.
Discussion Starter · #6 ·
Ok thanks will look into it.
