1983 Mercedes 280SL
Currently trying to source a length of vacuum hose. Does anyone know what sort/size of hose I ask the hose people for? (Pictured). Does it need to be 'vacuum' or will any same size nylon hose do?
Any help much appreciated
Thanks.
1997 SL500- 40th Anniversary
I have heard of folk using silicone hose, although I must be missing something. I would think the silicone hose would be too flexible and collapse in uses where the vacuum is dead-headed, like a diaphragm actuator.
'80 450SLC Afro RHD Ikonengold
When I installed additional vacuum hose for aux electric pump to make central locking system independent of engine vacuum, I ran a nylon hose from a scrap VW Golf. It was given for free (with purchase of other things).
If original hose is not brittle but just cracked, use 1" silicone hose to patch - bridge broken parts.
There are dedicated vacuum hoses that are guaranteed kink free but made of rubber... not a long life item in the engiine compartment.
1983 Mercedes 280SL
Thanks for your replies. I found some nylon hose which looks identical to the hoses laced about the engine. Wasn't advertised as vacuum hose but sounds like it doesn't matter.
Cheers
