hi,everyone and happy holidays. i replaced my valve cover gaskets today. a bit of a PITA. but i forgot to label the two vac lines that go over the passenger side valve cover. now i don't know which one goes where. they are parallel and run with the spark plug wires. and they have two rubber connectors where you can disconnect them to remove the valve cover.any help will be appreciated.
Not sure with yours being a 89 560, but on my 76 450 those lines go to the gold coloured vacuum diverter valve on the engine bay wall behind the coolant reservoir.
As for which line connects to the inner /outer outlet youd have to check the specific vacuum diagram for your car
it goes behind the coolant tank .since i've upgraded my computer i have problems opening my 107 cd.
thanks for the help. i took another look at it this morning. this time with a flashlight and i noticed one vac line has two stripes. while the other has only one. so i just matched them up.
