2002 C240
I've been away from benzworld.org for a long while. Sorry to be a fair weather friend. However, I need some advice. I have a V60 PSE and cradle in a 2002 C240. I'm using a bluetooth puck, but some of the electronic connecting pins in the cradle are sticking*. When that happens the puck won't work.
Any advice on how I can get the connectors to loosen up?
Thanks,
Dick Gleason
*there are three pins on one side of the connector and one of the outside ones is sticking.
W221 & Audio Moderator
2013 S550
You may have better luck with a V60S cradle; it is slightly larger than the V60 cradle, and doesn't fit the puck as tightly.
Alternatively, you might inquire whether the new "cradle eliminator" will work with your existing PSE; if so, you could bypass the cradle altogether, and plug the V60 puck into it. It runs about $160 or so. I do know the "cradle eliminator) came out with the new "Universal PSE" that is meant to allow folks to equip their older cars with Bluetooth, since states are requiring handsfree systems more and more. It may very well work with your V60 PSE.
