Hi,
I have 1998 Ambiente 230 (V class). I need some help with a problem, especially as I can't find any manuals and my local dealer charges seventy-five million pounds an hour!
The right indicator works fine, but the left goes on and stays on without flashing. If I use the hazards, then both sides work fine. Sometimes after using the hazards, I can get the left indicator to flash for a bit, then it stays on continually. I've pulled out the 2 flasher units at the base of the steering column and swapped them over, but the fault does not transfer, the left side still has the problem.
Also, don't know if this is related, but the instrument lighting fuse blows continually. Any ideas (apart from using a six inch nail as a fuse!)?
Thanks in advance
Thanks in advance
