Hi,
Can anyone help out there, I have just found out that the cooling fan is not coming on at all temperature almost goes off the gauge. I have fitted a new sender unti from Mercedes made no difference! Checked the fuse under the passengers seat in order to. Had a look through previous threads unable to locate the fuse on top of the radiator?
That aside is the throttle body ECU something to do with the gearbox, as I get a transmission warning light come on during certain throttle positions??
Many thanks.
Vito 111CDi 2004
I am not suggesting that this is a long-term measure by any means but i did have my fan hard-wired to a switch once in an old banger for the same fault, until you figure out what it is. Hot engines are not fun.
