61 - 80 of 80 Posts
Golf R32 / Prev R170 SLK
Discussion Starter #61
Cont;
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P0805 Clutch Position Sensor Circuit Malfunction
P0806 Clutch Position Sensor Circuit Range/Performance
P0807 Clutch Position Sensor Circuit Low
P0808 Clutch Position Sensor Circuit High
P0809 Clutch Position Sensor Circuit Intermittent Ckt
P0810 Clutch Position Control Malfunction
P0811 Clutch Slippage Excessive
P0812 Reverse Input Circuit Malfunction
P0813 Reverse Output Circuit Malfunction
P0814 Trans Range Display Circuit Malfunction
P0815 Upshift Switch Circuit Malfunction
P0816 Downshift Switch Circuit Malfunction
P0817 Starter Disable Circuit
P0818 Driveline Disconn. Switch Input
P0820 Gear Lever X-Y Sensor Circuit
P0821 Gear Lever X Sensor Circuit
P0822 Gear Lever Y Sensor Circuit
P0823 Gear Lever X Sensor Circuit Intermittent Ckt
P0824 Gear Lever Y Sensor Circuit Intermittent Ckt
P0830 Clutch Position Switch A Circuit Malfunction
P0831 Clutch Position Switch A Circuit Low
P0832 Clutch Position Switch A Circuit High
P0833 Clutch Position Switch B Circuit Malfunction
P0834 Clutch Position Switch B Circuit Low
P0835 Clutch Position Switch B Circuit High
P0836 4 Wheel Drive Switch Circuit Malfunction
P0837 4 Wheel Drive Switch CKT Range/Perf
P0838 4 Wheel Drive Switch Circuit Low
P0839 4 Wheel Drive Switch Circuit High
P0840 Trans Fluid Press Sensor/Switch A Circuit Malfunction
P0841 Trans Fluid Press Sensor/Switch A CKT Range/Perf
P0842 Trans Fluid Press Sensor/Switch A Circuit Low
P0843 Trans Fluid Press Sensor/Switch A Circuit High
P0844 Trans Fluid Press Sensor/Switch A CKT Intermittent
P0845 Trans Fluid Press Sensor/Switch B Circuit Malfunction
P0846 Trans Fluid Press Sensor/Switch B CKT Range/Perf
P0847 Trans Fluid Press Sensor/Switch B Circuit Low
P0848 Trans Fluid Press Sensor/Switch B Circuit High
P0849 Trans Fluid Press Sensor/Switch B CKT Intermittent
P1000 Electronic Gear Selector Module: Defective N15/5
P1228 yet unknown code on 1997 C 220 CDI
P1386 knock control
P1570 Intermittant No-Start Immobiliser Module
P1581 ?
P1747 Electronic Gear Selector Module: Defective Interaction of CAN
with control unit A1(instrument cluster)
P1750 Electronic Gear Selector Module: Very low control unit supply
voltage
P1832 Electronic Gear Selector Module: SHORT in circuit N15/5 output
stage
P1910 Electronic Gear Selector Module: Control Unit over voltage
P1912 Electronic Gear Selector Module: Weak touch push button voltage
P2000 NOx Trap Efficiency Below Threshold (Bank 1)
P2001 NOx Trap Efficiency Below Threshold (Bank 2)
P2003 Particulate Trap Efficiency Below Threshold (Bank 1)
P2004 Particulate Trap Efficiency Below Threshold (Bank 2)
P2031 Exhaust Gas Temperature Sensor Circuit (Bank 1 Sensor 2)
P2032 Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 2)
P2033 Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 2)
P2080 Exhaust Gas Temperature Sensor Circuit Range/Performance (Bank 1 Sensor 1)
P2081 Exhaust Gas Temperature Sensor Circuit intermittant (Bank 1 Sensor 1)
P2100 Throttle Actuator Control Motor Circuit/Open
P2101 Throttle Actuator Control Motor Circuit Range/Performance
P2208 transmission: The speed of Y3/6n2 to Y3/6n3 is excessive
Body
B1000 HRA Headlamp range adjustment: Supply voltage of the control unit is too low (undervoltage)
B1004 LCP Lower Control Panel: Control unit does not match vehicle type
B1056 Automatic Air Conditioning: Problem in CAN communication with control unit DCM-RL
B1201 Electric seat adjustment front left: Hall sensor front height
M27m3
B1213 If seat memory installed: ext left rearview mirror voltage faulty
B1214 If seat memory installed: ext right rearview mirror voltage faulty
B1226 In-car temperature sensor (B10/4)
B1227 Outside temperature indicator temp sensor (014)
B1128 Heater core temperature (B10/1)
B1229 Heater core temperature (B10/1)
B1230 Evaporator temperature sensor (B10/6)
B1231 ECT sensor (B11/4)
B1232 Refrigerant pressure sensor (B12)
B1233 Refrigerant temperature sensor (B12/1)
B1234 Sun sensor (B32)
B1235 Emissions sensor (B31)
B1241 Refrigerant Fill
B1246 PTS Parktronic: A42b1 (left outer sensor, front bumper) The plug connection has poor contact or is loose, or the sensor or cable is faulty
B1310 Left/Window airbag sensor is defective
B1315 Problem in Front passenger child seat recognition
B1416 Coolant circulation pump (M13)
B1417 Duovalve (Y21y1), left
B1418 Duovalve (Y21y2), right
B1419 Electromagnetic clutch (A9k1)
B1420 Idle speed increase
B1421 Pulse module (N05)
B1422 Series interface (K1) connection to instrument cluster (A1)
B1423 Switchover valve block (Y11)
B1424 Activated charcoal filler actuator (A32m2) open
B1425 Activated charcoal filler actuator (A32m2) closed
B1432 Non-USA DTC
B1459 Series interface (K2) connection to instrument cluster (A1)
B1462 Wide open throttle (WOT) position signal diesel engines
B1476 Airbag malfunction indicator and warning lamp is defective
B1481 HRA: Part E2m1 (Right headlamp range adjustment motor) has short to ground
B1489 HRA: Part E2m1 (Right headlamp range adjustment motor) has open or short to positive
B1492 HRA: Part E1m1 (Left headlamp range adjustement motor) has
short to positive
B1617 Part E19/1 (Left license plate lamp) is defective
B1618 Part E19/2 (Right license plate lamp) is defective
B1628 Part E2e5 (Turn signal lamp) in module E2 (Right front headlamp unit) is defective.
B1703 Intermittant No Start in AAM Immobiliser Module
B1729 PSE Pneumatic system doorlock Control Module A37
B1736 Navigation system's CD Player: Check General CD, Check CD data block, Flimsy CD data
B1768 Faulty open data flap limit switch (0025) Front flap
B1773 HRA: Zero position programming has not yet been carried out or is not possible
B1850 Electric seat adjustment front right: CAN communication interrupted with DCM
Chassis
C1000 Traction System Control Module
C1010 Battery Voltage Low
C1011 ASR/ETS/ESP Circuit Open or Shorted
C1012 Battery Voltage High
C1020 CAN Communication Fault
C1021 CAN Communication With EA/CC/ISC Control Module Interrupted
C1024 CAN Communication With Engine Control Module Interrupted
C1025 CAN Communication BAS communication with ESP control unit faulty
C1100 Left Front Axle VSS Circuit Fault
C1101 Right Front Axle VSS Circuit Fault
C1102 ETS/ASR, ABS Left Axle VSS Circuit Fault
C1103 Right Rear Axle VSS Circuit Fault
C1121 AIRmatic: fault in component B24/3 (acceler. sensor)
C1122 AIRmatic: fault in component B24/4 (acceler. sensor)
C1123 AIRmatic: fault in component B24/6 (acceler. sensor)
C1132 AIRmatic: fault in component B22/8 (level sensor)
C1133 AIRmatic: fault in component B22/9 (level sensor)
C1135 AIRmatic: fault in component B22/3 (level sensor)
C1140 BAS light, play in steering column causes steering angle sensor to lose memory(?)
C1142 ABS Lateral Acceleration Sensor Open/Shorted
C1144 AIRmatic: fault in component B7 (pressure sensor)
C1200 Stop Light Switch Open/Shorted/Implausible
C1300 Left Front Axle Solenoid Valve (Hold) (A7/3y6) Open/Shorted
C1303 Right Front Axle Solenoid Valve (Hold) Open/Shorted
C1311 Switchover Solenoid Valve (Release) Open/Shorted
C1312 Master Cylinder Switchover Valve
C1401 High Pressure Return Pump Circuit Open/Shorted; Will Not Shut Off
C1501 SPS P-Valve
C1504 BAS light, play in steering column causes steering angle sensor to lose memory(?)
C1512 Brakes Overheated
C1600 Temperature After Engine Is Turned Off
Discussion Starter #62
Cont'
New Systems
U0001 High Speed CAN Communication Bus
U0002 High Speed CAN Communication Bus Performance
U0003 High Speed CAN Communication Bus (+) open
U0004 High Speed CAN Communication Bus (+) low
U0005 High Speed CAN Communication Bus (+) high
U0006 High Speed CAN Communication Bus (-) open
U0007 High Speed CAN Communication Bus (-) low
U0008 High Speed CAN Communication Bus (-) high
U0009 High Speed CAN Communication Bus (-) shorted to Bus (+)
U0010 Medium Speed CAN Communication Bus
U0011 Medium Speed CAN Communication Bus Performance
U0012 Medium Speed CAN Communication Bus (+) open
U0013 Medium Speed CAN Communication Bus (+) low
U0014 Medium Speed CAN Communication Bus (+) high
U0015 Medium Speed CAN Communication Bus (-) open
U0016 Medium Speed CAN Communication Bus (-) low
U0017 Medium Speed CAN Communication Bus (-) high
U0018 Medium Speed CAN Communication Bus (-) shorted to Bus (+)
U0019 Low Speed CAN Communication Bus
U0020 Low Speed CAN Communication Bus Performance
U0021 Low Speed CAN Communication Bus (+) open
U0022 Low Speed CAN Communication Bus (+) low
U0023 Low Speed CAN Communication Bus (+) high
U0024 Low Speed CAN Communication Bus (-) open
U0025 Low Speed CAN Communication Bus (-) low
U0026 Low Speed CAN Communication Bus (-) high
U0027 Low Speed CAN Communication Bus (-) shorted to Bus (+)
U0028 Vehicle Communication Bus A
U0029 Vehicle Communication Bus A Performance
U0030 Vehicle Communication Bus A (+) open
U0031 Vehicle Communication Bus A (+) low
U0032 Vehicle Communication Bus A (+) high
U0033 Vehicle Communication Bus A (-) open
U0034 Vehicle Communication Bus A (-) low
U0035 Vehicle Communication Bus A (-) high
U0036 Vehicle Communication Bus A (-) shorted to Bus (+)
U0037 Vehicle Communication Bus B
U0038 Vehicle Communication Bus B Performance
U0039 Vehicle Communication Bus B (+) open
U0040 Vehicle Communication Bus B (+) low
U0041 Vehicle Communication Bus B (+) high
U0042 Vehicle Communication Bus B (-) open
U0043 Vehicle Communication Bus B (-) low
U0044 Vehicle Communication Bus B (-) high
U0045 Vehicle Communication Bus B (-) shorted to Bus (+)
U0046 Vehicle Communication Bus C
U0047 Vehicle Communication Bus C Performance
U0048 Vehicle Communication Bus C (+) open
U0049 Vehicle Communication Bus C (+) low
U0050 Vehicle Communication Bus C (+) high
U0051 Vehicle Communication Bus C (-) open
U0052 Vehicle Communication Bus C (-) low
U0053 Vehicle Communication Bus C (-) high
U0054 Vehicle Communication Bus C (-) shorted to Bus (+)
U0055 Vehicle Communication Bus D
U0056 Vehicle Communication Bus D Performance
U0057 Vehicle Communication Bus D (+) open
U0058 Vehicle Communication Bus D (+) low
U0059 Vehicle Communication Bus D (+) high
U0060 Vehicle Communication Bus D (-) open
U0061 Vehicle Communication Bus D (-) low
U0062 Vehicle Communication Bus D (-) high
U0063 Vehicle Communication Bus D (-) shorted to Bus (+)
U0064 Vehicle Communication Bus E
U0065 Vehicle Communication Bus E Performance
U0066 Vehicle Communication Bus E (+) open
U0067 Vehicle Communication Bus E (+) low
U0068 Vehicle Communication Bus E (+) high
U0069 Vehicle Communication Bus E (-) open
U0070 Vehicle Communication Bus E (-) low
U0071 Vehicle Communication Bus E (-) high
U0072 Vehicle Communication Bus E (-) shorted to Bus (+)
U0073 Control Module Communications Bus Off
U0100 Lost Communication with ECM/PCM A
U0101 Lost Communication with TCM
U0102 Lost Communication with Transfer Case Control Module
U0103 Lost Communication with Gear Shift Module
U0104 Lost Communication with Cruise Control Module
U0105 Lost Communication with Fuel Injector Control Module
U0192 Lost Communication with Television
U0197 Lost Communication with Telephone Control Module
U0198 Lost Communication with Telematic Control Module
U0222 Lost Communication with Door Window Motor A
U0235 Lost Communications with Cruise Control Front Distance Range Sensor
U0301 Software Incompatibility with ECM/PCM
U0302 Software Incompatibility with TCM (Transmission Control Module)
U0303 Software Incompatibility with Transfer Case Control Module
U0321 Software Incompatibility with Ride Level Control Module
U0326 Software Incompatibility with Vehicle Immobilizer Control Module
U0327 Software Incompatibility with Vehicle Security Control Module
Bazzle :D
Discussion Starter #63
More Codes some small differneces .
Mercedes W202 OBD-II Codes
1997-2000
Return to 202Tech How-Tos
Glossary of Acronyms
DTC SAE Nomenclature Explanation
P0100 MAF Circuit Malfunction Hot film MAF sensor
P0105 MAP circuit malfunction Pressure sensor
P0110 IAT circuit malfunction IAT sensor (in hot film MAF sensor)
P0115 ECT circuit malfunction ECT sensor
P0120 Throttle Position Circuit Malfunction Actual value potentiometer in actuator
P0130 O2S 1 circuit malfunction O2S (before TWC) voltage increase insufficient
P0133 O2S 1 Circuit Slow Response O2S 1 (before TWC) A. Aging correction value exceede.
B. Aging time period too long
C. Sensor response too slow long.
P0135 O2S 1 heater circuit malfunction O2S 1 heater (before TWC)
P0136 O2S 2 circuit malfunction O2S (after TWC)
P0140 O2S 1 circuit malfunction O2S (before TWC)
P0141 O2S 2 heater circuit malfunction Right O2S 2 heater (after TWC)
P0150 O2S 1 circuit malfunction A. O2S 1 heater (before TWC)
B. O2S 1 heater (before TWC) voltage increase too slow
P0153 O2S 1 circuit slow response A. O2S 1 heater (before TWC), aging correction value exceeded
B. O2S 1 heater (before TWC) aging time period too long
C. O2S1 heater (before TWC), aging O2S1 sensor reponse too slow
P0155 O2S 2 heater circuit malfunction Left O2S 2 (before TWC)
P0156 O2S 2 circuit malfunction Left O2S 2 (after TWC)
P0160 O2S 2 heater circuit malfunction Left O2S 2 heater(before TWC)
P0161 O2S 2 heater circuit malfunction Left O2S 2 (after TWC)
P0170 Fuel trim malfunction A. Self adaptation of fuel mixture "partial load" (Inline 6, Inline 4 (Right cylinder bank for V6) at limit from engine control module.
B. Self adaptation of fuel mixture "CTP" (Inline 6, Inline 4 (Right cylinder bank for V6) at limit from engine control module.
P0173 Fuel trim malfunction A. Self adaptation of fuel mixture "partial load" left cylinder bank (V6) at limit from engine control module.
B. Self adaptation of fuel mixture "CTP", left cylinder bank (V6) at limit from engine control module.
P0201 Injector circuit malfunction - cyl 1 Injector - Cylinder 1
P0202 Injector circuit malfunction - cyl 2 Injector - Cylinder 2
P0203 Injector circuit malfunction - cyl 3 Injector - Cylinder 3
P0204 Injector circuit malfunction - cyl 4 Injector - Cylinder 4
P0205 Injector circuit malfunction - cyl 5 Injector - Cylinder 5
P0206 Injector circuit malfunction - cyl 6 Injector - Cylinder 6
P0207 Injector circuit malfunction - cyl 7 Injector - Cylinder 7
P0208 Injector circuit malfunction - cyl 8 Injector - Cylinder 8
P0243 Recirculated air flap actuator for supercharger For engine with supercharger only
P0300 Random misfire detected A. Random misfire
B. Random misfire, TWC damaging
P0301 Cylinder 1 misfire detected Cylinder 1 misfire, TWC damaging
P0302 Cylinder 2 misfire detected Cylinder 2 misfire, TWC damaging
P0303 Cylinder 3 misfire detected Cyilnder 3 misfire, TWC damaging
P0304 Cylinder 4 misfire detected Cylinder 4 misfire, TWC damaging
P0305 Cylinder 5 misfire detected Cylinder 5 misfire, TWC damaging
P0306 Cylinder 6 misfire detected Cylinder 6 misfire, TWC damaging
P0307 Cylinder 7 misfire detected Cylinder 7 misfire, TWC damaging
P0308 Cylinder 8 misfire detected Cylinder 8 misfire, TWC damaging
P0325 KS 1 circuit malfunction Front KS 1
P0330 KS 2 circuit malfunction Rear KS 2
P0335 CKP sensor circuit malfunction CKP sensor
P0341 CMP sensor circuit range/performance Camshaft Hall-effect sensor
P0370 Angle deviation between camshaft and crankshaft Angle deviation between camshaft and crankshaft
P0400 Exhaust gas recirculation flow malfunction Exhaust gas recirculation malfunction (logic chain)
P0410 Air injection system malfunction AIR system malfunction (logic chain)
P0422 TWC efficiency below threshold (left on V6) TWC efficiency below threshold (left on V6)
P0432 TWC efficiency below threshold (Right on V6) TWC efficiency below threshold (Right on V6)
P0440 EVAP system malfunction EVAP system leak (logic chain)
P0441 EVAP system incorrect purge flow EVAP not functioning
P0442 EVAP system leak detected (small leak) EVAP system small leak
P0443 EVAP system purge control valve circuit malfunction Purge control valve
P0446 EVAP system vent control malfunction A. Activated charcoal canister shut-off valve
B. End stage activated charcoal canister shut-off valve
P0450 EVAP system pressure sensor malfunction A. Fuel tank pressure sensor electrical fault
B. Fuel tank pressure sensor electrical fluctuations
C. Purge monitoring pressure sensor
P0455 EVAP system leak detected (large leak) EVAP system, large leak
P0460 Fuel level sensor circuit low input Fuel tank level too low
P0500 VSS sensor malfunction A. VSS left front
B. VSS left rear
P0507 ISC RPM higher than expected Idle control system
P0560 System voltage malfunction Voltage supply at engine control module
P0565 Cruise Control Switch CC Switch
P0600 Serial communication link malfunction CAN bus from ESP/SPS control module
P0604 Internal control module random access memory (RAM) error Engine control module
P0605 Internal control module read only memory (ROM) error Engine control module
P0700 Transmission control system malfunction Read DTC memory of transmission control module
P0702 Transmission control system electrical Read DTC memory of transmission control module
P0715 Input/turbine speed sensor circuit malfunction Read DTC memory of transmission control module
P0720 Output speed sensor circuit malfunction Read DTC memory of transmission control module
P0730 Incorrect gear ratio Read DTC memory of transmission control module
P0740 Torque converter clutch circuit malfunction Read DTC memory of transmission control module
P0743 Torque converter clutch circuit electrical Read DTC memory of transmission control module
P0748 Pressure control solenoid electrical Read DTC memory of transmission control module
P0753 Shift solenoid A electrical Read DTC memory of transmission control module
P0758 Shift solenoid B electrical Read DTC memory of transmission control module
P0763 Shift solenoid C electrical Read DTC memory of transmission control module
P0801 Engine/climate control electric cooling fan malfunction Engine/climate control electric cooling fan
P0802 Resonance intake manifold switchover valve Resonance intake manifold switchover valve
P0803 Air flap/air filter actuator malfunction Air flap/air filter actuator
P0805 Supercharger function Supercharger function
P0806 Magnetic supercharger clutch Magnetic supercharger clutch
P0809 Angle deviation between camshaft and crankshaft Angle deviation between camshaft and crankshaft
P0811 CAN from electronic ignition lock CAN from electronic ignition lock
P1031 O2 sensors reversed O2 sensors reversed
P1163 Oil level switch Oil level switch
P1177 Oil sensor Oil sensor, Oil temperature implausible
P1178 Oil sensor Oil sensor, Oil level implausible
P1179 Oil sensor Oil sensor, Oil quality implausible
P1180 Oil sensor Oil sensor, Oil temperature too high
P1181 Engine/climate control electric cooling fan malfunction Engine/climate control electric cooling fan functional fault
P1182 A. Starter lockout relay module
B. Starter relay Starter relay in passenter-side fuse and relay module box
P1185 Oil sensor Oil sensor, water in oil
P1186 Fuel safety shut-off recognized EA/CC/ISC actuator
P1225 Resonance intake manifold switchover valve Resonance intake manifold switchover valve
P1225 Throttle valve setting Throttle valve setting element sticks due to icing
P1233 EA/CC/ISC actuator icing problem EA/CC/ISC actuator icing problem
P1235 Supercharger function Supercharger function
P1236 Magnetic super charger clutch Magnetic clutch function
P1386 Knock sensor control from ECM at end stop Knock sensor regulation from engine control module at end stop
P1400 EGR switchover valve malfunction EGR switchover valve
P1420 AIR pump switchover valve AIR pump switchover valve
P1453 AIR relay module AIR relay module in passenger-side fuse and relay module box
P1491 Refridgerant pressure in A/C system too high Refridgerant pressure in A/C system too high
P1519 Adjustable camshaft timing solenoid Adjustable camshaft timing solenoid (logic chain)
P1525 Adjustable camshaft timing solenoid Adjustable camshaft timing solenoid
P1542 Pedal value sensor Pedal value sensor
P1570 CAN signal from DAS control module to engine control module A. Start attempt with "locked" DAS
B. CAN signal from DAS control module to engine control module interrupted.
C. Engine control module and DAS control module are not compatible.
P1580 EA/CC/ISC actuator Throttle valve setting element
P1584 Stop lamp switch Stop lamp switch
P1603 CAN signal from EIS CAN failure
P1605 Poor road/traction condition recognition signal (via comparison of VSS rpm signals)
P1642 Engine control module incorrectly coded Engine control module incorrectly coded (Coded for MT, vehicle has AT)
P1643 Engine control module incorrectly coded OR
No CAN transmission from transmission control module Engine control module incorrectly coded (Coded for MT, vehicle has AT) OR
P1644 Transmission version cannot be checked due to low voltage at transmission control module Transmission version cannot be checked due to low voltage at transmission control module control module
P1681 Crash signal not plausible
P1747 CAN signal from ETC A. CAN failure: Transmission protection malfunction from transmission control module
B. CAN failure: Instrument cluster
Bazzle
Discussion Starter #72
Wheel alignment specifications
Standard SLK Alignment should be about--------------
Camber.....
Front: -1.22 +/- .33 degrees
Rear: -1.5 +/- .5 degrees
Toe in .....
Front: 2.28mm +/- 1.14mm total
Rear: 3.78mm +/- .8mm total
Caster......
Front: 5.2 degrees +/- .5 (.5 diff max between sides)
Suspension height.........measured from wheel centre to lip of guard
Front: 350mm standard /325mm minumum
Rear: 370mm standard / 340mm minimum
Standard SLK all models.
Bazzle :D
Discussion Starter #74 (Edited)
K40 Relay - Right hand drive
LHD opposite :D
Remove neg batt term
Remove computer lid
Unclip holding tang and lift up module
Pull off connectors
Open case of module
Inspect soldered joints for cracks, overheating, dry joint etc
An eyeglass may help:eek: (top left hand group of three)
Remove old solder and resolder with new
Replace module
Push on connectors
Remove and replace 40A fuse to wipe the contacts.
Replacelid
Replace neg batt terminal.
Start car :thumbsup:
Redo radio code if required.
more: http://www.benzworld.org/forums/r170-slk-class/1263021-k40-relay-circuit-associated.html
Bazzle
97 E420 Sport
In regards to code P0500: If all the wheel speed sensors have been changed and my car is still in limp mode and I'm still getting this code, what should be my next step?
Very good rundown and pics on the K40 Bazzle. In a former post I queried as to why you referenced the fuse panel being on the wrong side. DUH I forgot you all drive on the other side of the road down there. This car is much fun to drive, has a minor quirk or 2, but nothing major. Wife will not ride a Harley and the price is about the same. I thank everyone for the posts that keep it on the road extremely helpful stuff. Thx Bazz you da man. '99 SLK 230
Mercedes SLK 230
Bazzle, I have emailed you before and you were very helpful, might I intrude on you again please. I have a 2001 230 slk and its throwing a code P0222 which is the throttle pedal position sensor switch B. I can't find hardly anything on it in here. What I have found is 1. replace the whole gas pedal. 2. replace only the sensor on the gas pedal. Which is it? I am a pretty little women but how in the world are you suppose to even get in there to replace the silly thing. We are going to have a ice storm the next couple of days so odds are I will not be attempting it until the weather gets a little warmer since I have no garage here where I have just moved. I'd appreciate any help you can pass along. Penny
Penny, Bazzle is a sometime visitor now that he has sold his SLK - often chimes in tho'
Hope someone else helps in the meantime. Regretfully not my speciality
Oberoi
Mercedes SLK 230
Bazzle Lost
Sorry to hear about that. He was very knowledgeable about these cars. Thanks for the info though. You said its not your area, could you brush up on that for me so it could be your area??:D
61 - 80 of 80 Posts
