Well, well we haven't had a URO post in awhile.
My Aux fans went kaput - one had a wobbly shaft, the other had a broken fin. New fans from MB are a staggering $450 ea (x2). I needed to replace quickly and I like ordering from Autohauz but all they had to offer was U know who.
I thought gee it's just a fan with a motor. what could go wrong?
Replacing these on the 119 is pretty straightforward (and messy) but still 2-3 hr job. Put the new fans in and my wife and I went out for a drive. The car warmed up ... and warmed up ... and warmed up to like 110. Something definitely wrong and I got it back home. Fans were running hard like they should but no drop in coolant temp.
Did some research and found that the fans should spin clockwise (as you stand in front of the car). There is a sticker on the MB fan (that I didn't notice) showing this.
So I ran the new fans again and sure enough both of them are running counter clock wise. I thought damn, I plugged them in backwards. Tore it apart again to get to the fans and their connectors which live between the fan and condenser. So I finally get the fans off and the connectors are just like MB in the pic below. There is locator pin so that it can't be connected backwards.
That leaves only one other explanation - the wires were installed backwards at the URO ching/chang plant. Opened up the housings and switched the wires around. Put everything back together again and it's running correct now (we'll see how long). Thanks, fuckers, for making me do this twice.
If you're buying these aftermarket, bench test them first. I never dreamed that they'd be sent out like this.
