W210 E280 2000
My ride is a W210 2000 E280V6 right hand drive.
I think the passenger side upper ball joint is worn out as there is a noise and movement at the joint when I rock the tyre sideways.
Understand the upper ball joint can't be repaired, the whole upper arm has to be changed. Am I right?
If so, is this a DIY job? (I notice there will be access problem when removing the bolt holding the arm to the chasis).
All views and ideas would be most appreciated.
1998 E320
It doesn't look like your original post got any reply--did you figure it out on your own, have any best practices to share?
Thanks!
