Very nice! What size wheels and tires are you running? What style wheel is that? What shocks/struts/springs?This is 84----190E transform to a new look give u some idea :-add on side pannel replace back bumper,replace front bumper,grill and euro headlight........
what u think,,,,,,,,,,,,ain't look to bad !
What springs?I believe is from SLK 16 X 7 1/2 & 8 1/2 and wrapped aound with 215/40/16 tires all the way around........
Thanks I need to lower my front, I have KYB shock/struts, but the stock springs and due to the lower profile 16" tires there is more wheel gap than I like, I am trying to find out how much lower it would go with lowering springs, I was looking at H&R,Rear 400E Eibech & 500E HR Frnt
190E 16v Blistein sport all round.........
I have 205/50/16 all around and I have some wheel gap, mainly up front, I don't want to have to roll the fenders, and I don't want to lower it and then have rubbing issues when I go over hills, I had that issue with the old stock shocks and struts, they were worn out and had no life left so every time I went over hills the fronts rubbed badly, I replaced the shocks/struts and now no problem, ex the wheel gap.My other one have a set up eibech coil spring all a round....and for me i prefer eibech rather then HR
a better smooth ride with a stock schock than came with the car when i bought it
rear 225/50/16-----16 x 7 1/2
Frnt 205/50/16-----16 x 7 1/2
No rubbing issue on the fender after I rolled the fender
good with 4 adult passenger aboard.......
I was looking at theseWhat i believe stock diameter tires 24'4 and you size tire is 24'1 another word is smaller than a stock height that give more gap on the lowering spring if u go with HR
W201 2.3 1984-93 Sport Spring/Touring w/o self-leveling
1.3 1.25 Sport Cup Kit 2.0 1.7
So is your choice my friend ...................
but i guest is depend on the offset of the wheel and width of the wheel
My 16V had a set up 245/40/17 rear & 215/40/17 frnt
no rolling fender no rubbing but I'm using sport cup kit with blistein sport all a round 17x8 1/2 check it out.......
Billsteins are prob better, but would it eliminate the wheel gapKYBs suck. Get Billy sports
