HI
wanted to know if anyone has done this or if its doable,,seems like it would be..
CAN you take the FRONT brake discs and calipers on a E550 AMG P21 package car , that are 13 inch cross drilled 4 piston
and move them to the REAR, replacing rear ones,,
and then
put larger 14" BREMBO, or EMC discs and 6 piston in the front..
I know the new front brakes part is possible, but is moving existing front Merc stock brakes to rear possible as long as its done as a complete set move.
want to know because the stock front brakes are essentially excellent cross drilled high performance AMG brakes, that are fine for the rear and better than stock rear brakes, and would be perfectly fine with new brembo's in front and alot cheaper than buying 4 new brake sets
thanks
and then
thanks
