As long as they're wheels from an early 560 or late 380, there won't be any problems.robtotis said:My 82 380 SL has the original 14 inch wheels. What problems should I anticipate if I upgrade to the latter 15 MB wheels ?
You're close. it's actually 25 mm but you can go up to 30mm with no spacers.graybeard said:If you go custom, make sure that the wheel offset is correct, I think the 380 is 30MM. I think my 16" aftermarket wheels are 30mm:
