1998 C180 Elegance
Hi, just found this site.
I have recently purchased a 1998 C180 Elegance Auto.
I've been looking around to see where I can get an owners manual from, with no joy so far. There's a warning light that has come up on the dash board (looks like a box with a filler cap & wave shape at the bottom of it). It looks like it shold be warning of low fluid levels, however I've checked all the fluids & everything seems fine.
I need some help please
If I'm understanding you correctly that light represents the coolant and possibly other stuff related to the cooling system. Not sure what all can trigger it. Someone else should be able to be more specific.
1998 c230 170K
If it is designated as the cooling light I would pressure test the radiator cap & radiator.
Perhaps the is an issue with the coolant system not properly pressurizing. Also have a look at your overflow tank condition.
As we know sometimes sensors go bad as well or even just a loose connection will flag a light, so check your plug connections. B
