Replacing original radiator on the E300D 210.025 Found this smaller CONTECH
belt laying in the area of the radiator and
it’s air baffle
Curious if anyone knows what this is specifically location ?
Safe motoring !
Many Thanks to MrBoca and Deplore for all the valuable insight, direction and support
with my ESL faults and failures all resolved.
Looks to be the auxiliary fan belt. When you spin the aux fan, does the other fan spin as well?
The only other belt apart from the serpentine belt is the belt that is between the front aux fan motor and the fan assembly next to it.
That has to be what it is will check in AM
Thank you both for you’re replies
In the Radiator, Mounting and Covering
screen EPC, item 164; I see V-belt round shape like this one with Part number
A 011 997 00 92 -
This one likely original in bad shape will need to be replaced
