Some more machining of the extension of the transmission shaft. It fits perfect. . More bolts in my adapter contraption.
Hung the tdi motor.. smooth ..
Mounted the cab without raising it. Just to confirm clearances. Fits nice. The tires are 40" ..if I do not need to raise the cab for tire clearance then I will leave it like this.
Need to cutout the aluminum adapter plate a little more to easily mount the starter motor with the cab on.
Now more time can be spend on the clutch... cable or hydraulic. At the clutch pedal the attachment moves 27.5 MM... The first lever is 155 MM the one inside the bellhousing 85 MM.
So at the clutch plate the movement is about 15MM. sounds reasonable, will see what the TDT clutch requires
Also now more in the picture are the remote oil filter....front engine mount/ alternator mount.
Johan
Johan
