Howdy folks, Happy 2021.
Have been thinking about diesel conversion for a while and think I have read most threads and posts on this and other forums.
We are attempting a camper with our second 404 and would like the fuel efficiency of the diesel. For that reason the TDI above the OM617.
In this camper the 404 cab will be hard connected to the camper shell.. all on pivoting frame...and the front seats of the 404 will have swivel so that the cab becomes part of the living space.
For that reason I do not want to reduce the cab area or modify the engine dog house unless it is going to be smaller.
The cab will be raised about 2" to make space for 12.5-R20 tires
Looking at the available picture and taking some measurement it seems that if I pull the TDI engine to the front of the mog and remove the alternator and oil filter then it all could fit with out interference.
The front of the 404 engine bay is wider ( 22") with space for the original distributor. This would help with space for diesel pump. With alternator removed less then 20". Worst case would be to use the pump duse engines BEW and so on.
The 5 speed transverse manual transmission of the TDI can be split and the engine / bell housing section can be used as spacer / adapter.
This would have several advantages:
-TDI flywheel / clutch assembly can be maintained, power upgrades are available
-Clutch cylinder is already attached to bell housing.
-Starter is attached to bell housing. along the transmission
-readily available.
- the lighter weight TDI engine slid to the front gives max pressure on the front axle.
Another adapter / spacer has to be manufactured to adapt from the TDI bellhousing / half transmission to the bell housing of the 404.
M180 engine length 31" with pulleys... without fan.
TDI ALH 18"
TDI 5spd bellhousing / half transmission 5"
TDI ALH with transmission 32"
Problems:
Depending on that exact space the original TDI starter will not interfere with the 404 bell housing. unknown
The TDI ALH 5 speed has no pilot bearing and the input shaft no stub for a pilot bearing.
The TDI ALH longitudinal transmission has a pilot bearing so a shaft swap with bearing might need to happen.
The TDI transmission shaft has to be extended and adapted to the 404 input shaft , probably nicest with the spline of the clutch.. It looks like the 404 shaft's spline id long so for best alignment maybe two clutch centers could be welded together
The differential housing has to be cuttof from the TDI transmission.
ideas.
ideas??
The TDI with 5 speed is about as long as the M180.
Potentially the cover 5th gear steel cover of the 5 speed can be removed, the transmission gutted and an adapter flange from the back of the transmisisson can mate to the 404 bell housing.
The splined old 5th gear can be welded to the clutch spline of the 404.
Bearing would have to be replaced with enclosed ones or if pilot bearing/ new shaft is used then both tdi transmission bearings can be removed.
In the pics of the TDI / 5 spd.. the starter motor is removed.
Anybody has tried / see this approach?
Johan by
-readily available.
TDI ALH 18"
Problems:
ideas.
ideas??
Johan by
