Anybody have a tip on how to easily remove the black/white check valve under the dash? My hands don't fit up there...cluster out?
Is that for the engine shut-off? If so, take the cluster out, you can see it and reach it quite easily.
No, it's on the yellow line that supplies vacuum to the door locks. Still, it's up there behind the cluster. It's either that check valve and/or the vacuum switch on the driver's door that's bad. Still, it's up there behind the cluster. Just wanted to ask before tearing more of the car apart and buying parts. Thanks,
