none
I have the filter. It is the one that goes under the passenger side dash, or at least I believe it does. Is it simply a few screws to remove, pull and replace? Or is there something more. Thanks!
As an aside.....how does one turn on the headlight wiper blades? Just curious, as I must have missed it in the owner's manual.
1996 S320 (Kuro) 1998 S600 (Weiss)
Hi,
Sorry I don't have any info on the filter however from what I've experienced and read so far the headlight wipers are are controlled by a combination of the headlights being on and the windscreen washer being used.
Moderator
3phase-4pole
you got it.
tried it for once just for the hell of it.
and I believe it was the first time it was activated since the car was new since black water came out of the washers for a good 2 seconds before clear water came out
1999 S500 GRAND EDITION (32,800 Miles)
This should solve your underdash filter problem.
Removal and Installation ::
1 Turn latches (2) on recirculating air filter housing in passenger foot well 90° counterclockwise (open). To close during Installation, turn 90° clockwise.
2 Remove cover with recirculating air filter towards bottom.
3 Open recirculating air housing.
4 Remove recirculating air filter.
NOTE : The recirculating air filter cannot be cleaned, it always must be replaced.
5 Installation is in the reverse sequence.
1999 S600 98K miles, 1994 E320 Cabriolet 13K, 2012 GLK 24K
Latches on later 140's?
On my 1997 there are no longer latches to turn - you have to slip a screwdriver up each slot and release two plastic catches that keep it closed
