1991 180E 1.8L Petrol
HI everyone, this is in a way a follow up post to a previous post from a few months ago. My 180E had been sitting for quite some time. I have replaced the battery (to the correct size), a new fuel pump and filter has also been fitted. After fitting the pump and filter and jumping - the car ran/idled freely (albeit quite rough) for a short time allowing me to move it to properly charge the battery. When trying to start the car the next day it would not start/idle. Now it will only run with several some foot on the accelerator. This also causes lots of smoke to billow out. I am stumped!
Ive pulled the plugs and they are very black (likely from all the priming of the fuel pump in trying to get it to start. I have released as much of the old fuel as I could and diluted with new fuel however still unable to get an idle (even a rough one at that). Any help would be appreciated!
· Super Moderator
1986/1990 W126
Hi. Can I recommend putting your car model and year into your profile for us some time please? It's really helpful - Complete your Profile
When you say jump, you mean started from another car? Sometimes this can damage the OVP. Might be worth checking.
2002 Mercedes Benz ML 320
1. What color is the smoke?
2. If it is white could be a bad head gasket
3. Have you replaced the Oxygen sensor?
4. If so did you re set the fuel ratio on a lambada tool or a four gas scope with the tailpipe probe inserted?
5. What color/ condition is the oil?
6. If the oil looks like a milk shake then you have a bad head gasket
7. What color is the coolant/ anti freeze? If it is a green & tan color then you have a bad head gasket
8. Have you tested the fuel pressure with a fuel pressure gauge?
9. Have you performed a compression test? If so what was the readings?
10. A common problem with the 190 E is the computer/ engine management system but I don’t think you have the equipment to test it
