1 - 8 of 8 Posts
1980 280CE; 1982 300CD
This looks promising. New manifolds from a 1979 300SD next to my original equipment for the 1982 300CD.
FB
2618082
2618083
Discussion Starter #2
I can’t wait to not reinstall all that plumbing and vacuum control.
FB
'84 300d, CA version. Blue inside, silver outside. All the bells and whistles, some of which work!
Nice. Junkyard? I keep my EGR on there because it's inspected every 5 years. If there are capped off ports, I might fail.
No inspections here. And my EGR was all caked shut upon removal.
The manifolds came from the engine shop that rebuilt my motor. I think they were left behind on an abandoned rebuild.
FB
Of course, I’ll be saving all of the parts. Just in case...
FB
Wow. I hadn’t noticed that. That’s cool- should make the car breathe a little easier.
Drive pressure- is that like measuring EPR on a Pratt?
FB
Yes. Using a pressure gauge twice the range of boost helps determine if the turbo is working efficiently in the 1.0-2.0:1 range.
Too much boost for the amount of fuel burned and the ratio can be above 2.5:1. For the 617 with stock valve springs, ~35psi is the safe limit.
I laugh when I hear of people running 15-25+psi boost from their stock turbo, the drive pressure is insane with that antique turbo, mainly bacuse of its horrible wastegate design.
1 - 8 of 8 Posts
