450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro 300sel5spd R+C107galore
I have a habit of buying cheap Mercedes for the love of learning the models and making my money back by parting out the cars if needed. This one seemed like it would be hard to beat with a running and driving car albeit no reverse.
I was going to pay full price until the seller pulled out the clearly salvage title. In the shop we've got a transmission from a 1989 m103
300se w126 that should bolt in, but won't have any of the electrical connections, possibly making the car go a little haywire, but I have no clue. The salvage title was a deal breaker, and despite having the car loaded on the Dolly, I was ready to dump it and drive home without this project. The seller accepted my max offer, which wasn't much, but neither was the asking price.
So this mess of a car had virtually no coolant, no power steering fluid, and no transmission fluid. After dragging it home (after the seller drove if forward up onto the Dolly), we checked the fluids and basically got everything working correctly other than the reverse gear. Nada. In fact, when rolling backwards down a hill and you drop it into reverse, the car stops. Reverse acts as more of a brake than a reverse gear.
I understand that the transmission in this car is most likely a 722.6 (based on the VIN in the EPC) and it's not like any of the fluid transmissions of all my earlier cars.
The transmission fluid smelled very burnt. After filling the trans fluid, the car seems to want to hold onto lower gears and not upshift. Also, I noticed that it would often slip when hitting the gas from a coast at higher speeds.
Finally, as we were about to party the car for the night, I heard a groaning noise. We tracked it down to the transmissions by noticing the sound went away when We put the car in gear.
Anyway... although the car has a salvage title and no reverse, I honestly have a new appreciation for the w140. It might be dangerous. Previously I'd wanted a w220, but will now have to look at w140.
