What are the differences between these three vehicles? I know the -50 designates long wheelbase, and the -00 designates short wheelbase however I have read a number of blogs where people refer to the -00 as also having a 3250mm wheelbase.
Of course, I know a guy that has a U1300 that the cab plate says "L37" but its a 3250mm wheelbase, so, I take every rule with a grain of salt nowThe "L" in the model number in all Unimogs stands for longer frame. The additional length is all behind the rear axle. In the case of the two 1650's it's a 376 mm difference. The "standard" or short frame models are designed to be used with a full range of rear implements and such as PTO's and three point hitches, backhoes, etc. The longer frame models are designed for installation of fixed bodies and are not available with Rear PTO's, three point hitches, nor suitable for heavy rear mounted implements. A lot of people assume the "L" is an abbreviation for LKW or Lorry? Nope, it simply is the first letter of "lang", the German word for long.
There is some variation in how MB used the designation. For instance instead of the model U1700 L/38, they had, for a time, a model called "U 1700 LL" meaning long frame and longer wheelbase. They finally standardized on the current convention of all "L" models are wheelbase of 3250 mm except when designated with "/37, /38, etc.." (Of course they had to violate their own system when they built a few long wheelbase models with short frames.) Thus you have such as a "U2150 /38". Look Ma. No "L"
the original u1700 with the 435 chassy had 3.25 meter wheelbase. however when they went to 437 chassy, the U1700 had 2.8 meter wheelbase while the new U1750 was the new 3.25 meter wheelbase.My confusion occurred when I started noticing people referring to their u1700 unimogs as having a 3250mm wheelbase. As far as I know, the unimog u1700 has a 2810mm wheelbase.
This makes the most sense. Unless they are an L3x, the older ones are 3250. I have never seen a short 1700 but, then I never search beyond the years I can import to the USthe original u1700 with the 435 chassy had 3.25 meter wheelbase. however when they went to 437 chassy, the U1700 had 2.8 meter wheelbase while the new U1750 was the new 3.25 meter wheelbase.
if you apply the xx50 rule to anything that was done around 1990 and later, then it works. i think thats about the time that they started using this labaling.This makes the most sense. Unless they are an L3x, the older ones are 3250. I have never seen a short 1700 but, then I never search beyond the years I can import to the USThe 1750's I have seen are 3250 as well.
The the one mog constant applies here too, there really are no rules.
My U1250 was an '86 and had the 3250 mm wheelbase, so the system was in place then.
The U1200's being the Shortys.
if you tell us what your needs are, the right unimog could be recommended and then you can just research that particular type.Hmmmm......I really need a manual on Unimogs. I have been researching, and if there is one obvious truth about them, it's that no two are the same.
Sage advice.also keep in mind that research is only so good. unless you get true reliable info, often false things get repeated and eventually become facts.
