2005 W220 S500 4Matic / 2008 W211 E350 4Matic
So first let me point out that I have searched for both of these problems all day to no avail, most likely due to a million different causes, but please bear with me and toss in your two cents if you have any ideas. The car is a 1990 300SE.
First problem is with the heat. It works fine at idle/low RPMS, but accelerating or revving the engine makes it go cold. If the car is idled up to full operating temperature prior to driving, this problem does not happen. If you start it and then drive soon thereafter, you only get heat at idle. I cleaned and tested the monovalve and it seems to be fine, and I know it is clean and clear. WTF?
Second problem is with performance when the engine is at temperature. The car starts smoothly when cold and drives as it should - drives great actually. New EHA seals, fuel filter, plugs, valve cover gasket, injectors with seals, resealed fuel distributor, replaced cat with straight pipe, new OVP relay, new MAS, and several other recent maintenance items. When the car gets warmed up however, it will stumble and misfire off the line. It will barely accelerate at any degree of pedal pressure and will stumble harder the more you press the gas. Once rolling up past about 10mph the car again drives fine. The workaround I have figured out is to hold the gas down a bit with my foot on the brake at lights or stop signs, or while in traffic - as if about to do a brake stand. If I hold it at 1100rpms for about three seconds, it idles smoothly again and will take off from the stop smoothly. The car will start hot, but requires a bit more cranking. If you crank until it seems to fire up it will go up to idle and then die immediately - holding the key in the start position for about two or three seconds will keep it at idle and it will stay idling smoothly. The car always idles smoothly regardless of engine temperature. Big WTF.
Any help or ideas would be very sincerely appreciated. Both problems are getting severely annoying.
Why would you remove the cat? The computer is probably confused after it warms up and switches to a closed loop using the O2 sensor.
Dan
Cat was clogged. These problems predate the cat (which was hollowed out - the housing is still there with a functional O2 sensor in it) and have not been affected by the cat hollowing.
I also should mention that for the heat issue, when the car gets back down to idle, it does not automatically get hot. You have to roll the temp selector all the way to full cold lock and then back to full hot lock to get heat. It does not matter how quickly or slowly you do this. Works every time - until you accelerate again.
One idea I had on the rough acceleration issue is that it might be related to a fuel accumulator. Does anyone think this is plausible? I'd like to start ordering some parts to throw at this.
1995 E320 (totalled) 91 420SEL W126 (retired) 2002 S500 W220(retired); 2008 C300 Sport W204
Sounds like it could be the fuel pressure regulator is acting up. Located next to the fuel distributer in the fuel intake line. Check to make sure the vacuum end of the regulator is attached to the vacuum source and also check to make sure fuel is not seeping out of the vacuum end of the regulator.
