2002 VW Golf TDI
Hey guys
I have a 89 560SL and Im tired of the dim turn signal indicators on the dash. Can I make them brighter? Or can I make the turn signal audio indicator louder?
Thanks.
BenzWorld W126 & W201 Host
1988 420SE, 2002 C180 Kompressor, 200 ML320
Turn signals
HIDgolf
Higher wattage bulbs should do the trick, but i wouldn't know if they are available.
Take the old ones out, go to your nearest bulb stockists, and see if they can match them with a higher wattage.
2002 VW Golf TDI
Re: Indicator lights
my self to overcome the problem I use a low volume buzzer paralel with the indicators.
Where did you get the buzzer? Would you care to share about the install?
I would really appreciate it.
