1990 300SE, 1983 300D
My turn signals dont work. I replaced all the fuses, and still, nothing. I would check and see if the hazzards worked, but the switch is screwed up. The park lights work. I also cant put on the park lights and fog lights. Anybody know what these problems can be?
1984 300D Turbo
fog lights only work when headlights are on and on low beam.
turn signals are related to the hazard swich. replace hazard switch.
'06 CLS500 '01 CLK320, '84 300D
You already answered your question. All signals are linked to the hazards. Benz bin has them for under $20. This happened to my old 190E.
G
On your model year the directionals
and emergency flashers work thru the
4way flasher relay.
It is located under the wooden shifter
panel in front of the shifter.
It will be a black box laying on it's
side.
Replace this and all should be fine.
Louis.
