2001 E320 W210
So this morning I'm turning left. I signal and make the turn. My left side signals continue to flash eventhough the turn signal switch has returned to the middle position. When I signal right, it flashes right, but when the switch on the column returns to the middel(center) position the left turn signals start to flash. Is this a relay issue or is there something wrong in the steering column? Any suggestions?
Thank you,
2002 e320
I had the exact same problem. I pulled the fuse for the turn signal(not the wisest thing from a safety standpoint.) Then I ordered a new turn signal stalk from autohausaz for about $65 shipped and had an independent mechanic switch it out, There is a sticky for doing the r/r yourself but I did not feel comfortable doing it myself.
Paul
