´85 300D Estate, Unimog 411
The pressurized oil line that goes to the turbo broke down, I end up runing in the highway with clouds of lightblue smoke. After all not big problem.
The thing is that this line is a copper line (like gas lines) welded to banjo bolts.
IS the original line copper, stell or a hose?? I Prefer to change it to a high pressure hose, but like to hear your thoughts before.
It's metal of some kind, but not copper, as I imagine that would be too soft.
1984 300D
I believe the Original is Steel.
Copper is OK for handeling the pressure but Copper does not hold up to vibration well.
You can change it to a High Pressure Hose. Back in the 1970s Detroit Diesels and Cummins Truck Engines with Turbos all used the Hydraulic Hose with the Braided Stainless Steel cover for the Turbo Oil Supply.
You should be able to pic up a plate for the Turbo Inlet Oil that is already tapped with pipe threads from High Performance Car shops because the Garrette (Air Research) Turbo is a common Turbo used on gassers.
I believe you will have to fabricate the Fitting for the lower Oil Filter Area Banjo. Or, maybe a Hydraulic Shop would have a Banjo with the open end tapped with pipe threads.
Thanks I´ll go for the high pressure hose, and put banjo bolts on both ends.
