1981 U1300L
i am going to do a valve adjust that requires moving some of the turbo plumbing. the turbo setup in not a stock setup as you may notice from the photo. my question is should i try to order the gasket in the circled area, or just make one? is this a stock mog part#? i'm assuming its just a flat paper gasket. thanks in advance, kris
2015 Rubicon Unlimited (Let the shame be upon me!)
The gasket should be relatively easy to make if you had to, dead soft sheet copper and some layout tools would have you set.
1981 U1300L
